My stairs are starting to feel unstable. I have them for 10 years. Is there some maintenance I should be doing? I have tightened the bolts at the top. It is a 6 step set of stairs. I can't see a n...
wnjj and tonymull - do you know what the height off the ground the top step is of your Little Giant Safety Step step ladder ? On the 3 step unit the spec's say 44" and on the 4 step unit the spec is 56" The spec says this is the stepladder height, so is that the height off the ground to the top step ? Also I am assuming that you both fold down the safety bar. Thanks for your response.
