06Fargo wrote:
The Dicor flexible lap sealant can be maintained by applying fresh sealant to the cracked areas. Look at you toob for videos showing how to clean and prep.
I would use the same brand and spec sealant that has worked from 2008 till now...
Wall opening sealant is a different product that is much stiffer.
This job took me an hour or so last summer on our truck camper
I do similar with selfleveling sealer, except, I use roof cleaner / then ck all seams for unusual or over large cracks in the old sealer then do more if necessary also it is very for us check as the deck on the rear of our house is the same height as the camper roof
ps NO silicone ever !!!!!!!!!!!
