maxum1989 wrote:
kohldad wrote:
We use and my father uses an elastic roof sealant paint. He has used it on his 97 Snowbird since the first crack in about 01. He paints the seals each or every other year as needed. If interested, I can get the exact name and more information when I'm home and can reach the can on the shelf.
This is what I do on my Northern Lite. Built pretty much the same as the Bigfoots.
I mask the edges with the blue tape and do the same thing except I use a soft caulking called SONOLAST because it is very good caulking. Stays like rubber and holds good for years. I use a stiff brush and spread till smooth going both directions for better adhesion.
I don't like the Eternabond tape idea because I think it would leave air gaps underneath going across small gaps or compound bends.
