TxGearhead wrote:
bigfootgrey wrote:
The product that Bigfoot uses is Heng's Roof Coat. It's a Alkyd - Fibered roof coating. I've used it on my camper with good results. Just clean previously coated area and remove any loose material and re-coat with a couple of thin applications,allowing dry time between coats. About $20.00 a quart but it goes along way!
Bob
Thanks Bob....exactly what I needed to hear.
Use the same product. In the cracks I apply extra so they fill. Tape off so you get a nice line...
In 16 years I inspect every year and touch up areas that are cracked. Some places it is now quite thick <>1/8in... The only time I have completely removed all the orig Heng's is to install a better bathroom fan.
Jim
