Hi guys. Midway through installing. I have the panels mounted and working through wiring. Looking for thoughtful comments. Here are a couple pics of install to date.
Might you want a disconnect switch between your solar controller and the solar panels, just in case you ever need to work on things in between? I guess you could just cover the panels to reduce their voltage to zero. I gave myself that option in my measly 200 watt system (yours is truly impressive!).
