bwlyon
Jan 29, 2021Explorer
I have a similar set up. S85RS Ascent camper on our 2015, 6.4 gasser Megacab 3500 SRW. Just like the Arctic Fox 811, the ascent is a SB camper with a slide, and it is heavy just shy of 5K fully wet and ready to camp. Now the 811 is a few hundred pounds lighter though, but only a few hundred fully wet and ready to go. You are going to be over every where with the exception of the steer axle. The 811 like my camper really needs to be under a dually. Like you we get by with the SRW, but our next truck will be a dually. Our weight fully loaded and ready to go is as follows. 13000lbs GRoss weight. With 8700lbs on the rear axle. That’s 1600lbs over GVWR, 1700lbs over rear axle capacity, 1300lbs over tire weight rating for the pair of rear tires.
44,056 PostsLatest Activity: Dec 27, 2025
