97fordrunner
Aug 31, 2020Explorer
mountainkowboy wrote:
Ours was 3/4" x 1" cross beams that were tied together with straps. I added a steel "stiffener" to the main support beam in the front. You have to be careful when setting the tension on the straps, I pulled mine to tight and needed to redo it to get the tin to work.
Was your side structure 7/8" ply? I feel like I saw that noted somewhere,
If it was I am having a hell of a time sourcing anything that thickness. if I can not what are peoples thoughts on going with 3/4" and 1/8" putting the 1/8" on the inner side and laminating it to get the correct thickness? Likely use screws as well from the inner side sporadically but would rely on the adhesive mostly.
44,025 PostsLatest Activity: Feb 26, 2025
