tcc11tccExplorerJun 19, 2013Tire questionI just got new tires and they state inflate to 44 PSI. Why did the dealer only put 32 PSI in them? I believe that is what it says to do on the door but these are different tires than what came on th...Show More
tcc11tccExplorerJun 19, 2013I suppose this means P rated, P275/60R20So you fill back ones to 40ish when towing and leave front at 32?For some reason I thought if you didn't have the tires inflated to where they were suppose to be, they wouldn't wear correctly?I always inflate my boat and campers tires to what they list as Max PSI because I was told to do that.Not very mechanical....can you tell :)
Related ContentTire chains questionsTire questionsToyo Tire questionAnother tire questionTire Wear Question
