Durb wrote:
Does the wind ever blow in Winnipeg?  Since you are buying new gear, I would budget in a Hensley or Pro Pride hitch.  This will give you some leeway to get the trailer you want.  Bigger is usually better when it comes to trucks.  My son has a Laramie 1500 Ecodiesel.  Payload is a shade under 1,100#.  He doesn't complain about the tow of his 5,000# boat but I know he is overloaded going to the lake.
Boats usually have under 10% tongue weight around 5% - 7%, while a travel trailer averages around 13% tongue weight. That's only about 350 lbs tongue weight from that boat. That is pretty light.
With a factory brochure weight of 5600 lbs for a light weight 30' travel trailer, you'll have far more. Add about 300 lbs for options on top of base weight, then about 1500 lbs to 2000 lbs for water, food, clothes, and other stuff loaded into the camper. Now that 5600 lbs camper is 7400 lbs. With a 13% tongue weight, you'd have 962 lbs. Quite a bit more than a boat.
