Old-Biscuit
Feb 12, 2016Explorer III
Re: Vehicle Keys - Key Fobs - Locked Out
Can you insert key into door, turn it and lock/unlock it?
If so......a regular key cut from yours will do same. Will only work on door lock.
I had one cut from my truck key/fob for entry.
Placed it behind license plate....had to drill larger hole in head of key so license plate screw would go thru it.
When needed I can use a dime to remove screw and retrieve door key.
Check Here for replacement
