Taffy_C
Apr 07, 2021Explorer
JBarca wrote:
Hi Daniel,
I have acquired a somewhat extreme retirement hobby, I restore old wet campers. Get them cheap, and make a project out of it. I'm very selective about they ones I want to do, as I'm not wanting to get into 100% restoring. I can build one from the ground up easier when they are totally gone.
A camper that old, been outside untouched for the last 6 years, there are leaks in places you cannot see yet, beyond the rear wall issue. There are ways and tools to inspect the camper more to find them, but in your case, you may not want to even go there.
Everything in that vintage camper is rebuildable, cost and time aside. Your first issue, you do not have the ability to do the work yourself. To hire this work out it not cost practical. You will easily overrun the $15K you paid for it 18 years ago and that is without the parts.
I found this link at the Jayco site, is this your 22U, a 2003? https://www.jayco.com/tools/archive/2003-kiwi-too-htt/
I am currently restoring a 21 footer, aluminum sided, different floor plan, but it had been leaking in the back corner for several years before I acquired it cheap. The water goes down inside the walls, stops at the waterproof membrane on the bottom and starts taking out the floor. And that was only the back wall leaks. As of today, I have 658 work hours into it and I will be a little over $5,500 in parts by the time I am done. I am about 90% done now. The only way this can may any kind of practical sense to do is, you do the work yourself and you enjoy doing it.
Hope this helps
John
John - didn't see your reply from a few days ago until just now. Thanks for those great insights - and yes that is the 22U I have. Yeah - I just don't have the chops or the time to do it myself - I wish I did! It must be tremendously satisfying to do the kind of restoration you do as a hobby! Thanks again.
Daniel.
44,028 PostsLatest Activity: Dec 15, 2014
