Badog
Jul 18, 2017Explorer
I am dealing with a failed magnetic lock on a Power Gear slide motor. The company will not sell a replacement part even though based on the design it is a failure point. the original owner of the MH had to pull the motor because the "manual override" for the lock did not work either. Based on the design it is no wonder. I was able to modify the manual override so it actually works and rather than spend $700.00 for a new motor assembly I will lock it manually. It is sad how poor customer service is and how poorly products are designed in the RV industry. That is why I tell non-mechanical people to stay away from RVing unless they have a good cheap mechanic or a good mechanical friend.
On the bright side the previous owner knocked several thousand off the price do to the defective motor. It probably would have cost them over $2K to have the motor replaced at the dealership.
44,056 PostsLatest Activity: Jan 12, 2020
