Cape_Cod_Mounta
Jun 02, 2015Explorer
Do pull and re-pack the bearings. You have never seen them so you cannot risk depending on leaving them un-inspected (Cost / benefit ratio). It is easy if a little messy. YouTube will have tons of good lessons.
Do NOT oil. They are made to run with high viscosity high temp bearing grease. Oil will change those specs and not last in the bearings but will get runny and leak off.
Go with manufacturer instructions over blogs - even RV.net.
44,027 PostsLatest Activity: Mar 05, 2025
