Scottishman
Aug 17, 2021Explorer
Skibane,
Thanks for that. Well, the only way I've found to rest the voltage delivered by the converter is to put a voltage meter across the two terminals that go to the battery from the converter (having disconnected the battery). It reads 13.62V. So I presume that's the charging voltage (?)
I also don't have enough faith in this (2016) converter to believe that it has two-stage charging as you suggest. I'll find the converter specs and look it up.
Thank you
Thank you
44,059 PostsLatest Activity: Mar 18, 2026
