Kayteg1
Jan 24, 2018Explorer II
The sticker payload is mean less with TC - you need to weight rear axle under the load and compare it to ratings.
Your pattern looks like your upper overload is barely working.
If you are comfortable with handling, that is all that matters (assuming you did not overload rear tires).
I added hockey pucks to my upper overload only to be on safe side, aka when I'd be forced to drive with filled-up rear tanks.
44,071 PostsLatest Activity: Aug 30, 2026
