Downwindtracker2 wrote:
When guys and gals are looking at purchasing a TT,they look at the brochure . But to get an idea of reality, our brochure weight dry was 4100#, the factory out the door sticker was 4600# dry ,when I ran it over the scale,fully loaded for an across Canada trip,the two axles were 2830 kg.(2.2lb=1kg).
This is all a so what to me, I switched out the axles to 5200# and the tires to either 2700# or 2900# truck, 16" 10plys .And I pull with a diesel 1ton. But someone with a 1/2 ton, might not have a so what attitude driving down the road.
This is 6226 lb loaded. Which means you are carrying a LOT of stuff---1626 lb. Unless that is batteries and water... I can't imagine where in a TT you would put that much weight.
