bnk190's avatar
bnk190
Realistic 1/2 ton towing
We are looking at getting a travel trailer. As we have looked though different trailers the desires change and where I first set a limit to a 20-24 ft travel trailer has now expanded to 30 ft and much greater weight.
Here is what I have.
Tow vehicle is a 09 F150 supercrew 4x4 with 3.55 gears and 5.4L. Per Ford I can tow 9700 lbs. Max GCWR is 15,500. Truck does have the towing package on it.
Per CAT (certified scale)and this is the truck full of fuel and how I would be towing. No human weight included but it's just 2 adults and a dog.
Steer Axle 3260
Drive Axles 2540
Total Weight 5800
Per the door sticker
7200 GVWR
Front 3750
Rear 3850
Now for the trailers.
Keystone Bullet Premier 19 FBPR
Length 23'2"
Shipping Weight 4213
No GVWR listed on site but with 2287 for cargo weight I am guessing it's 6500.
Hitch is 410
Jacyo 24T (For 2014 this will be a White Hawk 24RBS so weights may change)
Length 27'8
Shipping Weight 4465
GVWR 6250
Hitch 545
Artic Fox 22g
Length 23' 10"
Weight 4678
GVWR 7500
Hitch 550
Artic Fox 25P
Length 27'1"
Weight 6470
GVWR 10,000
Hitch 870
Artic Fox 25Y
Length 30'
Weight 6853
GVWR 10k
Hitch 760
So there are the trailer choices. I would like the larger Artic Fox eith the 25P or 25Y however I'm concerned over the weight and how much the truck will struggle.
I will also add there is no chance in upgrading the truck for at least 5 years. I'm also not looking to buy a shorter trailer now and upgrade when I get a bigger truck. I want to buy a trailer now and have it paid off when the new truck comes.
So I guess the question is how will a 1/2 ton tow 7200 lbs around? I also don't see us as heavy campers meaning we have to bring everything including the kitchen sink. I have camped many years ago and we only bring what we need and camp light. I also never travel with full water or waste tanks.
I have a feeling we will end up in either the Bullet or the Artic Fox 22G. Problem with Artic Fox is the closet dealer is 6+ hrs away but that's a different concern.
  • shutdown wrote:
    I am going to guess you will get many opinions here but here is mine: don't even look at a trailer with a 10k GWR. It is too heavy for your truck. The others should be OK.
    I appreciate the heads up and I figured there will be a you need a F550 crowd. I agree with you on not wanting to tow 10k with a 9700 lb tow limit but that is where I tell myself that by traveling light lets say I keep it to 7500 lbs. That is 2200s below the limit.
    7500 actual weight would give me about 700 lbs of cargo.
    I just don't want to sell myself short if the truck could do it but from the group so far and from what I had guessed to begin with it will struggle.
  • I am going to guess you will get many opinions here but here is mine: don't even look at a trailer with a 10k GWR. It is too heavy for your truck. The others should be OK.
  • romore wrote:
    It will tow that much but I don't think you will be happy with the results. It will struggle on the hills and fuel mileage will be abysmal. That much weight might push you around on steep downgrades. I honestly believe you should stick to around 5,000 lb to leave a comfortable margin.
    That is what I am thinking too but the what if question keeps coming in. Also what changed is we now want a couch and a dinette. That means adding length which adds weight. I am also very picky on floor plans, windows etc. I can tell you I have been looking for 2+ years and haven't found that perfect trailer.
  • RWDIII wrote:
    Any one of the first 3.Due you have a tow package?
    Ford tow package used to include 3.73.
    if you have 4 sp,you are going to spend a lot of time in 2nd and 3rd if you come out west
    They must of changed it with the 09. I do have the tow package but have the 3.55 rear end. Transmission is the 6 speed.
  • It will tow that much but I don't think you will be happy with the results. It will struggle on the hills and fuel mileage will be abysmal. That much weight might push you around on steep downgrades. I honestly believe you should stick to around 5,000 lb to leave a comfortable margin.
  • Any one of the first 3.Due you have a tow package?
