Great, thank you! It looks like my wheels are only rated at 3,525lbs, but I think I'm just going to stick with them. I'm more worried about the tires, but when I switch to the 295/65r20's, I think I'll feel ok. I'm going to see what we can ditch from the camper so we can drop some weight (I think the cast iron set has to go).
Tamnative wrote:
shabr66 wrote:
skanj0 - Thank you!! I don't know how I missed the lt295/65r20. I looked down a list of toyo mt's and looked for the highest rated tires and only saw the 18's. Now I just need to determine if my stock 20" wheels are rated in the same ballpark.
BCBigfoot106: I don't know what to tell you but that is what the scale said, and I seriously doubt there was a problem with the scale as it was an Oregon DOT scale. My freshwater was full and my fuel tank was probably at about 1/4. The truck is a diesel, but like you said, I don't think that adds too much weight to the rear axle. I did have a load of firewood in my rear basket carrier which probably weighed about 250 - 300lbs, but again, the weight was MUCH higher then I anticipated.
Check here to see if your wheels are listed:https://www.fleet.ford.com/truckbbas/non-html/2005/vs_pdf/05fseriessd-exlbb.pdf
