myredracer
Aug 04, 2014Explorer II
You could use a 10" whole house filter cartridge like this Pentek iron reduction cartridge for under $100. You'd also need a sediment pre-filter with it. Due to the low volume of water used in an RV compared to a house, it would last quite a while. Life would depend on the ppm iron content in the water and at 3 ppm for example, would provide 26,000 gallons of use. This filter will also remove manganese.
If this doesn't provide enough filtration, for a mere $1573, you could this one which filters up to 30 ppm: whole house iron reduction
Waterfilters.net is a good resource for filter info. and you could contact tehm for detailed info.
