spoon059
Nov 23, 2017Explorer III
PDX.Zs wrote:
Advantage Dodge? Not so fast. Their unit is replaceable, but requires MAJOR surgery and and aftermarket front dash replacement. Again, a punch in the neck should be mandatory here.
Not at all. Easy to disassemble the dash and there is simply a small and inconsequential metal bracing to remove (if you have the base radio) to allow a double din radio install. Super easy $16 install kit looks seamless. It takes 5 minutes.
Now... this applies to the base model ra1 or mid grade ra2 radio. No major surgery, no "front dash replacement" unless you are installing some custom shape radio... Replacing the 8.4 radio is more convoluted because the climate control and other features are built in to the radio (poor design in my mind... especially outside of warranty!)
For the newer Ford, I found this kit... https://pac-audio.com/catalog/radio-replacement/rpk4-fd2201 Looks like it replaces the 4.2" display with integrated climate control. More expensive and difficult... but at least an option.
I agree that its annoying that manufacturers are make such integrated radio's that are so expensive and difficult to replace. All the more reason that I enjoy "base model" trucks. Less expensive gadgets to replace.
44,067 PostsLatest Activity: Jun 03, 2026
