Ivylog
Mar 29, 2014Explorer III
When we only had a three speed tranny without OD axle ratio was very important. Unfortunately many have not figured out with just a 4 speed pulling a heavy trailer you do not need a 4.10 as keeping it out of OD and direct (the best gear to tow in) you have a 3.73. These same ones then say but off the line you need the 4.10 and with a clutch that might be true but with a torque converter... give me a break.
Not sure you need 8 as I love my PSD with a manual 6 speed. Pulling I use 5 of them unless I'm on a hill and then use the low hole to get started. Around town it becomes a 3 speed.
OP, for what you are towing I do not see any problem with a 3.09 by keeping it out of OD or on a good hill one gear lower, but you have to lift your arm and select a different gear. I would nor call that having to work.:W
44,066 PostsLatest Activity: Apr 10, 2026
