MitchF150
Mar 29, 2014Nomad
So, you are looking at the Dodge Ram 1500 with the reference to the 8 speed trans.. ;)
For reference, I have a 13 F150 with 6 speed and 3.73 gears.
In 6th going 70 mph, it's just a tick under 2000 rpms. I do have the 20" wheels, but the overall height of the tire is only 31.9". Same as the 18" and 17" wheel options.
To compare to my my 97 F150 with the 4 speed and 3.55 gears and roughly the same dia tires, it was about the same rpms going 70 mph..
But, the 97 would have to shift down to 2nd gear going up most grades while towing a #5000 TT.
I've not towed with my 13 yet, but just driving it over the last 2 months I've owned it, I can tell you I'm gonna be glad I got the 3.73's, even towing the same #5000 TT..
I'll bet I won't be any lower than 4th gear going up those same grades... RPM wise, that will put me in the 2500-3000 range. (the 97 would be 3000-3500 rpms)
So far I'm averaging 17 mpg in my empty commuting miles (1800 miles on the clock so far).
I'd vote the the 'lowest' (higher numerically) rear gear ratio you can get and enjoy the towing experience.. :)
Good luck.
Mitch
Good luck.
Mitch
44,066 PostsLatest Activity: Oct 04, 2013
