Golden_HVAC
Mar 29, 2014Explorer
Hi,
Either rear axle ratio will work fine. The truck will pick the highest gear that it can be in for a given load. So if you need 2,500 RPM to continue at a given road speed, then the truck will pick one of the 8 gear ratios and go with it.
With the 3.0:1 ratio, the truck can have a slightly lower engine speed, until it downshifts and can actually be turning faster than the 3.45 will have in the next higher gear on transmission.
So either one will make 200 HP at 3,000 RPM at say 45 MPH while going up a hill. If you need more power, either one will shift down one gear and bring up the engine RPM and increase the available HP as much as needed.
Fred.
Fred.
44,066 PostsLatest Activity: Oct 04, 2013
