rexlionExplorerMar 29, 2014Rear axle ratios and impact on towingSuppose you have a choice between two axle ratios, say they are a 3.09 and a 3.45. And let's say the vehicle has an 8 speed transmission, so there's plenty of gear flexibility. Ok, so there's roughl...Show More
goducks10ExplorerMar 29, 2014Biggest draw back will be acceleration thru the 1st few gears. After that the 8sp should even things out.
Related ContentTowing with 6.2l 3.23 gear ratioTowing lights issueIdle/Drive RatioTow RatingsTire aspect ratio
