Huntindog
Mar 30, 2014Explorer
It is not all about RPM. How and where the multiplication takes place makes a difference.
If the multiplication takes place in the transmission, then everything has to work harder. The tranny itself will work harder, usually shortening it's life. The u joints, usually won't last as long as if the multiplication was in the rear end gears. Engine braking will be more effective with lower rear end gears as well which will mean that the brakes will have a easier life.
Often in other wise identical TVs, the lower geared one will have a higher tow rating because of these factors
44,066 PostsLatest Activity: Oct 04, 2013
