Turtle_n_Peeps
Mar 30, 2014Explorer
C Schomer wrote:
The trans gears DO get closer together with a lower R&P! The top speed will be slower and you'll have the same number of gears so that makes the rpm change between gears closer. Mui bueno for towing! Craig
:R Oh boy!
If you have a 15% gear drop between 3rd and 4th with 2.73's you will have a 15% gear drop between 3rd and 4th with 4.56's.
The % stays the same!!!!!!!!!!!!!! Just because you have to make the gear change faster does not mean the % between gears or the ratio between the gears somehow magically changes.
This is almost as bad as people saying gears make more horsepower. :R
44,066 PostsLatest Activity: Oct 04, 2013
