campigloo wrote:
I’m getting ready to have the rear diff serviced and am considering adding an aluminum cover with heat sink. Have you gone this route? Does it make any significant difference?
I have 155,000 miles on my truck and looking at a leaking pinion seal. I have changed the synthetic lube every 40,000 or so miles. Not sure the cover would be worth the $300.00 for it.
Your opinion?
Thanks!
I'm wondering why you're even considering a $300 cover? Are you suggesting that the seal failing at 155 K miles indicates your oil was too hot? I'd change the seal, put new synthetic gear oil in and call it good. After another 150 K miles you can throw the whole truck out.
