falconbrother wrote:
Due to this thread... When I got home last night from a day of pulling the camper (5800 dry say--6800 wet) I checked my differential. It was hot as a firecracker (technical term). Too hot to hold your hand on. Not that it matters I guess. It was working hard pulling through about 100 miles of low mountains. I just serviced it before the trip. I have a small-ish pinion seal leak. I will fix that in a few days.
I found this info on a different forum:
Eaton conducted tests on oil/component durability during the late 1980s early 1990s
Their intent was to maximise seal and gear life and to allow the maximum OCI possible for their Heavy Truck gearboxes and diffs when using 75w-90 and SAE50 gear oils
They found;
a) components should not be operated at consistent temperatures above 250F
b) Intermittent operations to 300F do not harm the components or oils (synthetics)
c) Oils with a sulphur/phosphorus additive package activate rapidly above 230F.
d) A poor additive package in a synthetic lubricant may not be as good as a good (thermally stable) additive package in a mineral oil
My experience is that synthetic gear oils (75w-90 and SAE50) usually reduce operating temps by from 10-20C
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=516393
It sounds like you can get firecraker hot to the touch without causing problems (other than burning your fingers) and generally synthetics can take a little higher temps than the mineral oil that is referenced above.
I was going to change my dif oil but the service manager just told me that synthetic is standard in newer Fords so don't worry about it.
