The higher the gear ratio numerically (3.55, 3.73, 4.10, 4.30, 4.44, 4.56) the more revolutions your driveshaft has to turn to make the tires go 1 Revolution. This increase in gear numerical gear ratio decrease effort required to turn the tires thus making it easier for a vehicle accelerate and pull a load. If you have a light vehicle that does not pull heavy loads you can use a numerically lower gear like 3.08 which decreases the rpm of an engine at speed and thereby increase fuel economy. On the other hand, if you have a heavy vehicle that frequently pulls heavy loads you’d want a higher numeric gear ratio to make it easier to accelerate and pull heavy loads.
