I want to swap the rear end on my truck (99 dodge 2500 2wd 360 v-8) for one with 4.11 gears. Does anyone know of a cross reference that I can use to find what other vehicles have the same rear end as...
Nothing wrong with wanting to exchange the rear end. When you find one at a salvage yard, see if they'll let you pull the cover off of it while you're there so you can see if there's any busted teeth or pieces of metal inside before you leave. If not, at least pull the cover at home before you get started on the installation.
