I want to swap the rear end on my truck (99 dodge 2500 2wd 360 v-8) for one with 4.11 gears. Does anyone know of a cross reference that I can use to find what other vehicles have the same rear end as...
X2 on the gear swap! the 5.9L loves that ratio when towing. I had a 97 Dodge conv. van with the 5.9L and 3.55. when I swapped to a 3.90 it was a night and day difference! you will love the lower ratio (numerically higher).
I too would do the gear swap. much better than getting something unknown, that will more than likely need a rebuild anyway, usually the bearing are noisy with higher mileage.
