JRRNeiklot's avatar
JRRNeiklot
Rear hitch rack battery bank
I have installed a custom heavy duty hitch rack on the back of my 33 foot travel trailer. I have a battery box mounted there with six 6 volt batteries, charge controller, and inverter. Probably weighs 400 pounds. I didn't think it through when doing this and now I'm concerned that may cause sway or worse, be too much weight for the bumper to handle. It's a heavy duty bumper, and seems to handle it fine atm, but that's sitting in my driveway, not bouncing down the road. The rack has been welded to the bumper, but not the frame. Is this going to cause issues? The only other place I could put the battery bank is in the pass through storage under the bedroom, and I'm hesitant to do that due to venting. I'd hate to wake up dead!
As always, I'm grateful for any advice.
  • I just went over the trailer, looking for options. About the only other place is under the bed. This is essentially the same as in the pass through storage, but actually inside the trailer and I don't like the idea of sleeping on batteries no matter how well ventilated. Another option is putting the batteries in the storage area under the dinette, but that is on the slide out. I'm thinking that's too much weight to put on the slide motor.
  • Not that it's relevant to your original question but why do you need such a large battery bank?
    If you got the tongue weight from the brochure I wouldn't be surprised if it was really more like 750-800 pounds. Usually the brochure doesn't include propane, propane tanks or the battery. Slap another 400 pound battery bank on top of that and you're around 1200 pounds. Depending on what you're towing with that could be a lot of tongue weight.
    Going to be doing a lot of traveling when I finish this project and I will be boondocking most of the time. I was originally going to go with 4 batteries, but I got a good deal on 6 and had to take 6 to get that price.
  • I have a 22 ft Wildwood X-Lite backpack edition. The backpack means that Forest River put a fold down cargo carrier on the back. I can carry minimal weight back there with out causing sway. The sticker says 250lb capacity. It may hold 250lbs but 150lbs causes the trailer to handle differently. Storing heavier stuff under the front bed, filling front water tank, emptying rear holding tank, ect. will help but not worth the hassle. Maybe a heavier or longer trailer would handle the rear weight better but I think I would start with 2 batteries and build up from there checking for sway after each 2 batteries.
    I understand. A lot of folks who boondock for long periods of time get by with only 2 T-105 type batteries and use a small quiet generator like a Honda EU1000 or EU2000 to recharge the batteries when necessary. I can see how that would really help reduce the weights involved. I always try to use only 12VDC powered items to avoid the inefficiencies of an inverter.
    If you haven't found it yet, there's some good boondocking info at the link below. Good luck with your project.
    http://www.rv.net/forum/index.cfm/fuseaction/listings/forum/35.cfm
