Hayesgeorge's avatar
Hayesgeorge
Rear window replacement
I have a 1971 Kayot Forrester, the previous owner removed the rear window to install an air conditioner. My question is i don't want the air conditioner in there and would like to replace the window. It used to be a multiple Paine crank out style. Do you guys know a source or have an idea for replacement?
  • For reference sake when searching, these are called jalousie windows.
    Not the best for keeping the weather out, but certainly worked in years gone past.
    If you can find a local RV salvage yard, they may have something that fits.
    Might be a good time to put a more modern slider style in.
  • Is it a radiused or square corner style?
    If you can get exact dimensions, there are hundreds of RV windows on Fleabay. Most are new, surplus stock.
    Scott
