calewjohnson
Sep 08, 2013Explorer
Go Dogs wrote:
If they tell you they fixed a leak-skip it.
I also disagree. I had a leak in my front cap that the dealer could not fix. I pulled it apart myself, replaced all the particle board with actual wood and used laminate glue to reattach. Then used Eternabond on the seams, then put the molding back down. Is it perfect? No, but she doesn't leak one bit and the front has actual wood vice cheap particle board. Long story short, if fixed properly, there should be no problem.
Cale
44,056 PostsLatest Activity: May 04, 2014
