This is what is behind the plastic bin that holds the propane tanks. It had some insulation in there which you can see the remainder that has fallen out. I will be going in the morning to add new better insulation.
Cleaned out old insulation in prep for morning. The top bubble wrap was not installed by Lance. It is the bottom of a wardrobe above. I took the bottom plate out installed the silver wrap and a closed cell insulation above the propane tank plastic bin...made a big differance. It is fun to see that your old efforts did do some good.
The tub wing is gone as it had extensive rot cheaper to build new than repair old.
Another view of roof.
