OK..found and traced. It is solar wires. THere is a bundle woth tape around it stuffed in beside the battery box, which before the counter top goes on will be threaded into the bat box. The roof end is a fitting that was beside the old crack up sat dish. Lentz has the roof fitting and will install it.
The two small wire poking up thru the roof are the solar leads...they are a good heavy gauge wire as well.
While we were tracing that we began to wonder if we needed to run a wire set for the thermostat that will run the gas heater and the AC unit. In the roof hole we discovered a bundle of wires that seems to go no place...I took off the old stat and had a look...nothing I could see, so I removed the plug above and could see thru the bigger hole a bundle...had to make a wire hook to pull it out...voila stat wires for the AC unit...HOORAY!!!!
