Jeepers92 wrote:
Can you explain more about the matching of the roof (tpo?), to the nose?
Is the Filon edge (width), attached to the wood cross brace, then ribbion caulk, then the roof material covered with a trim stip?
Sorry for so many details, just tring to learn how the Pro's are doing it! Thanks for your help and sharing.
Yesterday, I spoke with David. Here goes: Rubber roof is glued down. then nose skin is brought over the top and glued with 221, and trimmed to correct position, held in place with board all the way across until cured. A alum trim strip is placed to cover the joint using butyl tape under strip. Trim screwed down and then self leveling caulk over the screws and trim...I'll get a picture when I get her home.
Hope this is what you wanted...let me know.
I will pick her up on Monday, 27th.
