Work on the inside is progressing nicely. Last Friday I was at the metal fab place at 0630 hrs and then to the countertop folks for a template and home by 1230, a good morning in my books.
This is what we have to cover, note the range hood is removed, 4 screws in bottom on cabinet and 2 in the back that do absolutely nothing, must make them feel good to think they did some good. One screw threads destroyed passing thru the metal hood and the other screwed inot the air portion of the wall.
Here comes the first cut for fitting.
End SS backsplash in place.
Installed and being held in place until silicone cures.
Then off to Lentz to get the window installed and sealed.
Now over at Lakewood Counter for the template fitting.
Uses old sample Formica as the template markers.
Installed with a hot glue gun.
New SS backsplash.
This is the hood fan damper, that does a lot of good ,but it works not dome with duct tape as so many others were. Still look at the gaps.
Cleaned the hood and removed the nasty noisy fan...need to replace it...NEED IDEAS PLAS!!!!
It is a 6' hole I need fan to fit in.
Amazing all these wires tell you so much about tanks and turn on light and fan and start the gen set with an hour meter.
All clean ready to go back in, wires are all plugs no issues there.
