Here to there...HUMMM!
After sitting with the plumbing expert at Lowe's for 45 min I got all the bits to make it work. Had TC with me so could go do some fitting and measuring the cashier gal got used to me going in and out.
First dry fit was awful, not that the up slope would matter that much it is a TC and moves...what to do to get it level? The trap must drop down! Drill it out...YES!!!
Seal with some wood finish.
Dry fir looks a whole lot better!
Glued up and tighten.
Install tap. All flex braided hose now, makes life simple.
All done!!!
Filled the tank to test then realized the range hood with the pump button is not installed...oh well!
Tuesday, next day edit: I hooked up the pump and filled the sink and no leaks anywhere...now system is undergoing a bleach sanitation regime! I really like the tap it feels good and has a snap detente system to keep it in place...should not have any issues! I can almost see the campsites along the road!!!
