Downwindtracke1
Oct 08, 2018Explorer
Right now I'm replacing the furnace on a '99 Adventurer 810, the original squealed like stuck pig, which made sleeping problematic. The fun of old campers.
First lesson : The 1/4 interior plywood is the main structural component in the walls. Leave it alone as much as possible.
If the 3/4" plywood tub on the bottom is rotten, walk away, you have your money in appliances.
Second lesson : you repair a stick and tin from the outside, the aluminum siding was the last piece put on. Pull off the vinyl strip by removing the stop screw at the bottom. I replaced mine with new strips . Pull the trim by removing the 1/4" headed #8 trailer screws with a nut driver bit in an impact or drill. Pry it gently off with a putty knife and a casing bar. Save it. For the siding, you start at bottom and pry the staples with a tack lifter , a screwdriver with a bent end, and pull with a needle nose vise grips. It's pretty easy.
Now you will see the rotten wood.
Don't despair, it is not that difficult to replace. There are two magic tools, a Fein multicrafter and Kreg jig. They allow you to cut out the rotten wood surgically and splice in good stuff.
Besides common wood working tools, like a jig saw and a table saw, you will need an air powered narrow crown stapler to put your siding back on.
When I put the corner molding on I use Proflex caulking, I don't want to do this again in 2 years, and #10 stainless screws. The one size larger bites in the original holes. Use Self Leveling for the roof vents.
I did all the sealing, the roof too, the wings, and the back end in three weeks on my hunting camper.
It's much better sealed than new and when I fit that 19,000 BTU furnace, warmer, too.
44,066 PostsLatest Activity: Apr 16, 2026
