Downwindtracke1
Oct 21, 2018Explorer
Yes, they use that formula in wooden boats. Works great they say. But if you let the wood dry , it usually just surface moisture, and keep it dry, the wood will out last you. The trick is to keep wood dry. That means doing a good job of sealing. I worked in the industry when I was younger, and have no use what so ever for grey butyl tape. They use poly urethane sealant, like Proflex, on the bottom of boats, that tells you something doesn't it.
44,066 PostsLatest Activity: Apr 16, 2026
