JoeChiOhki
Jul 30, 2017Explorer II
Monday, July 10, 2017
Rebuilding “Ms. Merry”, the Amerigo–Completing the Cabover, Part 2
We’re on a roll, now!
Soon, as we finished getting Ms. Merry’s new plywood walls done, we couldn’t wait to get to the next step, installing the first of the new finished wall board that would adorn all of the inside walls inside of Ms. Merry
Since our plywood boards fit so well, we decided to trace them onto their finish wall boards before we had glued them into place.
So, other than troweling on the flexible wall-board adhesive we’d selected and putting in the perimeter staples to keep everything nice and tight, it took very little time at all to really make Merry’s new walls look wonderful
The pattern on the finished wall board is called “Sea Mist”, though we’re not entirely sure where it comes from, as we’ve never seen a sea mist that looked anything like it.
For our friends that own Ms. Merry’s brothers and sisters, you may or may not have noticed, but as part of our redesign of Ms. Merry’s interior, we did away with the little wing shelf-thingies that were under the bottom edge of the wrap-around front window.
Given one of our main goals was to fit a full queen size mattress in Ms. Merry’s cabover, we saw no use to the little wings since our front ledge is anchored in place using a custom cut 2x6 and is securely attached to the cabover frame which supports it instead of the ledge trying to support the floor, as it was when we first brought Ms. Merry home.
The remaining void between the fiberglass body and the frame will be later filled with expanding foam, the low pressure variety so that it doesn’t accidentally deform the fiberglass body, this will insulate and remove any cold air voids near the front.
Once the main cabover walls were finished, the next part was to close back in the top front corners and install the insulation.
Yes, the gang and I decided to use pink bat insulation, we don’t have the tools to use expanding spray foam, which would have been ideal and the canned stuff wouldn’t have ensured an even insulation layer. Plus, if we ever need to replace the clearance lights, not embedding the wiring in expanding foam was a good idea
First we temporarily installed the corner boards to help hold the ceiling up while we removed the front board that had been temporarily screwed in place, then installed the fiberglass
The temporary bracing is to straighten the upper plywood ledge back out, the staples that held the bottom ledge for the front plywood had pulled out over the winter and had caused a bow to form in the shelf.
We glued and screwed the ledge back in place this time, so we’re going to leave it wedged up for a while to get the bow out.
Once that was glued and screwed into place, we next removed the driver’s side corner board, installed the insulation, then reinstalled the plywood.
You can see the extra piece we glued on the back to give us extra thickness to later attach the reading light fixture for Mrs. Dawn and the hole for the wires to come through.
Then we did the same (minus the wiring) on the other side.
