JoeChiOhki
Aug 17, 2017Explorer II
SATURDAY, AUGUST 12, 2017
Rebuilding “Ms. Merry” the Amerigo–Merry Raises the Roof–Part 2
When we last left you off, we were just getting the new rear roof framing in place for Ms. Merry’s bathroom.
We’re starting off in part 2, gluing in the five millimeter plywood cut to give the roof a crown around where the raised ceiling and vents are going to go. We’ve also framed in the last vent opening, for where Old Mr. Kit’s fantastic fan is going to be installed, replacing the original rear roof vent of Ms. Merry’s
Poor Mr. Dremel worked his heart out cutting out those openings, his little blades are all worn down to nubs, now
and my poor arms were jelly by the time we got done. Mr. Dremel’s going to have to take a break soon until we make a run to Home Depot to get him some more!
Once the holes were all done, we started fastening the pieces of old fiberglass roof in to the odd shaped holes and Mr. Dremel struggled on a little more to cut them flush to the new openings.
I think it came out pretty good, and once we clean and sand it, we’ll be putting some new fiberglass on to seal the roof all back up into once piece again
Thanks to the new Park Manager, Mr. Willy, we were able to get a ladder tall enough to get up topside of Ms. Merry and start the cleaning. For now, we just cleaned around the bathroom’s new vent opening so we could get it installed, there’s rain on the way and we need to get Ms. Merry battened down before it hits!
For Ms. Merry’s new bathroom vent, we went with a Ventline RV Roof Vent White w/ 12 Volt Fan.
The Gang and I really like really liked this vent because it unlike most of the classic Elxir and Jensen vents, the screen doesn’t require you to remove the interior trim ring to remove the screen for cleaning.
Just unclip and rinse, much easier than having to remove the knob, the anchor screws for the bezel, then the outer trim ring just to clean the screen!
We’re going to install a Camco vent cover over that vent later once the roof work is all done.
Can you believe it? We’re almost done with the roof!
Here’s our remaining work list, and then we can close it in!
Still looks like alot to do, but its all small things, a number of which can be done in a single day
. The slow one will be pull the TV wire, as we need to get some more parts to make more coax cables.
In the interim, we’ve gotten the holes drilled out for pull the light wires. Found the bit used for the Kreg Jig for the dimensional lumber is big and long enough to work great as an auger for drilling deep wire holes into bigger boards
Drills Milwaukee was able to bore clean through a 2x2 and a 2x4 without any trouble!
Our last piece for this chapter, we’ve cleaned the roof above where the raised roof frame goes in and glued and screwed it into place.
Next up, fiberglassing the roof in Part 3
- Pull the light wiring for the light above the dinette
- Pull the light wiring for the interior entrace area light
- Pull the speaker wire for the stereo speakers going on the underside of the dinette cabinet
- Pull the wire for the TV Antenna
- Pull the wire for the Radio Antenna (In theory we should be able to connect to the Winnegard antenna, but we’re not sure yet)
Pull the wiring for the bathroom light and bathroom fan - Pull the wiring for the Air Conditioner (First 110volt wire to be installed!)
- Pull the wiring for the porch light
