JoeChiOhki
Jul 08, 2018Explorer II
Monday, May 7, 2018
Rebuilding “Ms. Merry” the Amerigo–Merry gets a step up!
This is post is likely going to be fairly short, compared to the previous chapters. Sadly, I don’t have many photos handy of Miss Merry’s new steps from when their installation was finished, so I’m going to have to try and please you with this meager offering, for now
When you last saw Merry’s stairs, they were being test fitted into place. Sadly they had to spend a winter in storage before they could at last be installed in April. Sadly, even though I got an early start in March to close up some stuff on Merry due to a strange turn of warm weather, my progress has been fairly poor, due to either long bouts of sickness brought on by Oysters from the Oregon coast that for years have never given me grief, but now seem to be my baine.
Since last August, the underfloor paneling was installed after painting, then the spray skirt that protects the stiffener beam under Merry’s rear wall, then all the joints were caulked and the underside area received two more coats of flat black paint to ensure everything was well weather proofed.
The result is this.
Merry’s stairs hang down a good deal lower than the originals did, so traveling with the hitch extension in is a definite must to act as a drag guard for the rear of the truck. We’re already planning a rear cargo basket setup, which will use a dual receiver setup similar to the one on the front, for loading the generator and some other light gear onto for traveling, which will have a set of drag casters on it, similar to the rear end of a motorhome.
With the new steps, you can now climb up into Miss Merry, when on flat ground (Our driveway is sloped, as its made from a berm that we were not allowed to flatten as it is part of the levy, so I still need a set of cinder blocks to step up to the stairs) without needing a step stool to reach the first step.
One of the large swing away style stair handles will be installed to help give climbers more stability than the smaller grab handle can by itself.
Finding this particular folding stair set was actually rather difficult, as the Amerigo uses a fairly narrow stair, and most folding steps of this kind are designed for trailers, so they generally come with a wider tread, all of which were far too wide to fit in the space available on the underside of an Amerigo.
In the end, I wound up at RV Parts Nation, who was the only place online I’d managed to locate these narrow, triple step folding stairs.
The diagram is for the second SKU, which is 24” wide, but other than the tread width difference and subsequent housing width, different, the stairs are constructed the same.
For the stairs I used, the SKU is 1220 and you can find them here: RV Triple Manual Entry Step
Thanks for Reading!
The result is this.
Thanks for Reading!
