blt2ski
Oct 26, 2015Moderator
brulaz wrote:blt2ski wrote:
Then again, some trucks did not come with a factory hitch, as my 96 K3500, 2000 - C2500 and 2005 DW 3500. Kind of nice this way, as then you can choose a hitch that fits the needs you have, vs the engineers in Detroit etc, that do not know what you are going to do with the truck etc. I put higher rated hitches on ALL three trucks than came stock. The 96 and 2000 had 2" hitches, the 05 I went with a 2.5" hitch. The 2' were good to 10K with or with out wd bars. the 05 IIRC was around 15K with or with out bars.
Marty
I wonder if the hitch receiver ratings on factory installed hitches have as much to do with the whole truck as with the mechanical design of the hitch receiver.
My truck's factory hitch receiver has a WDH rating of 11,500# (1150# TW) but only 5000# (500# TW) weight carrying. Perhaps Ford is afraid that when you put on over 500# of weight carrying tongue weight, you will move too much weight off the front axle onto the rear axle. So they derate the WC rating of the hitch receiver to 500#, even though mechanically it can probably carry a lot more.
I'm not sure I would agree with this statement. As the amount removed on the FA will depend upon many factors. WB, rear overhang, spring rating, and the amount of wt on the FA. At least these have been factors in large and small ways from how much wt has been taken off the FA on my rigs. Some will say it is only the WB and rear overhang.....
The only trailer I towed with a WD was my travel trailer, which was around 7000 total, 5500-6500 on the axels, and 550-700 HW, depending upon how it was loaded, for how long a trip etc. My Equipment trailer I use to tow a bobcat, mini excavator, single or both at the same time, is 2800 empty with around 300 lbs of HW< upwards of 11K on the axels, and 1500-1600 HW. With one truck I lost just over 300 lbs on the FA with 6400 lb springs. Switched out to 8400 lbs springs, and the wt removed from the front went down some 60-80 lbs per local DOT scales.
marty
44,056 PostsLatest Activity: May 04, 2014
