myredracer
Jun 19, 2015Explorer II
mwhitedesigns wrote:
To clarify, when you speak of wrapping the wire with white tape, you are just doing this for identifying purposes correct?
It is Code required for identification and safety reasons.
mwhitedesigns wrote:Yes, and also as long as that is the breaker type that is listed and approved for use in the panel in your house (look for label inside the panel or match an existing breaker in the panel).
Lastly, the below breaker is sufficient, no?
http://www.homedepot.com/p/Siemens-30-Amp-Single-Pole-Type-QP-Circuit-Breaker-Q130/100025423
44,056 PostsLatest Activity: Jan 12, 2020
