kfp673 wrote:
pennysmom09 wrote:
The only time we use our second AC is to initially cool down the 5w after set up. The other use is to run the bedroom AC instead of the lower one in the evening so we can heat the tv. So, convenient, but not necessary
Curious about your "heat the TV statement". What do you mean by that. First I have heard of that. Thanks!
Typical LCD displays have problems operating in cold temperatures (below 30 - 40F is where you can start to see problems, though you probably wouldn't use an air conditioner to heat it -- even if it's a heat-pump/AC, those usually aren't very effective below 30-40F either.
Though judging by the context, pennysmom09 most likely meant "heaR", not "heaT". Our only AC is near the TV, and with the AC on, the TV is pretty much unusable.
