edatlanta
May 05, 2013Explorer II
TST 507 system here. I have had it for a little over a year and it works perfectly. The only time it has "saved me" so far was my error. I had checked the pressure in my 5'er tires late one evening before an early morning departure from a very quiet campground. I didn't want to run my air compressor immediately prior to departure out of courtesy to the other campers. Obviously I didn't screw the wheel sensor back on tight enough on one wheel and it had been leaking overnight. I had moved 50' or so and the TST alarm went off. Since I saw it was low pressure I left the park and stopped on the road right out front. Fired up my generator and compressor and aired the tire back up, it was only down about 10 psi, and went on my way. The TST system allowed me to watch that tire until I arrived at my destination. The pressure help up so obviously I was the error. I would have left the site with a low tire and not known it without a TPMS system.
Yeah I know if I hadn't had the TPMS system I wouldn't have made the mistake of not tightening the sensor enough, but then I wouldn't have the TPMS system either. At last I won't do that again.
