Keep in mind that keeping a 90%-100% SOC battery fully charged is different than re-charging a 50% SOC battery bank.
Charging Batteries with a solar controller is much the same as using your on-board converter unit.
When I re-charge a 50% battery bank my converter supplies 14.4VDC to my 255AH battery bank. The three batteries in this bank then immediately want to draw around 53AMPS DC current for a good 15-20 minutes and then start dropping back. Then after two hours of the 14.4VDC charge period the batteries are demanding around 8AMPS of charge from the converter. Then after two hours the converter switches down to 13.6VDC which drops the battery demand down to around 6AMPS DC Current. This will continue for another hour before returning my three 85AH batteries to a 90% charge state.
A single 120WATT Solar panel with a controller will only give you around 6 AMPS of Dc Current so this will take many hours to obtain a 90% charge state on your battery bank. If you start out with your batteries discharged down to their 50% charge state it ain't going to work to get your batteries back up to their 90% charge state in the remaining high SUN DAY.
Keeping the battery fully charged using solar is another story if it starts out at 100% charge state. If your consumption is low a single panel should be able to keep the charge up during the 8 hours of the SUN DAY.
For me this would not work as my battery demand is too high between 8PM and 11PM along with the 24/7 parasitic drains which equates to around 250-300WATTS of use. My batteries will drop from 90% SOC to 50% SOC by 8AM the next morning as read on my installed Battery Meter Panel. I do not think a single 120WATT SOLAR panel will replenish this SOC in the 8 hours of full sun time available in the one SUn DAY.
My rule is too never start using my 255AH battery bank for the day/night battery run unless it is at the 90% SOC.
My plan is going to be to install 360WATTS (three 120WATT PANELs) and do the initial battery charge each morning using the generator to get over the high 53 AMP charge cycle for two hours and then allow the solar panels to finish my 90% SOC rate before I run out of time of the high SUN DAY. When my 255Ah battery banks drops to around 12.0VDC I will turn it off to keep from doing damage to my battery bank.
This is my plan at any rate... The Solar guys are telling I will probably do great with my 360WATTS of solar panels giving me around 18AMPS of usable DC current during the high SUN DAY (Maybe around 108AHs total re-charge capability).
Just my thoughts for my upcoming SOLAR PANEL Project
Roy Ken
