mbloof
Aug 03, 2018Explorer
tcguy wrote:
Quick question. Is there a minimum or recommended clearance between the bottom of the cab over portion of the TC and the truck cab roof? I have a 2018 F350 and a 2018 Northern Lite 811 Q SE. I currently have a heavy duty rubber bed mat in the bed and with the camper loaded have 3/8" clearance between the roof of the truck and the bottom of the cab over. Is this enough? Thanks.
I think NL recommends at least 1.5" sheet (I"m using 2" foam sheet).
I found that if the two "bumpers" on the front bottom of the camper were in contact with the front of the bed, the tail lights might rub against the camper. I also put two cut sections of particle board between the front of the bed and the camper to move the camper back ~1" so there is clearance.
44,071 PostsLatest Activity: Aug 23, 2026
